Webinar: Integrated solutions for smaller, simpler low-voltage motor control design.
Join the webinar to experience!
Kathisai
5 questions asked 10 sign-ins First reply posted
Hi team,
I am working on the TLE9879QXA40, My requirement is to access the entire ROM, I found the ROM size as below:
But when I try to access the ROM above the address 0x1101F000, I can't read the data above the ROM address 0x1101F000 because the in keil target options the ROM size is 0x1EFFC (starting address of ROM i.e., 0x11000000 + 0x1EFF= 0x1101F000)
as below and facing an error
Error when tried to read the data above the address 0x1101F000:
But when I try to increase the ROM size in target options of keil I am facing an error as below:
My query is how can I read the data of ROM (flash) above the address of 0x1101F000.
Raj_C
500 replies posted 50 likes received 250 replies posted
Hi @Kathisai,
The TLE9879QXA40 has a 128 kBytes of ROM(FLASH). It's range can be seen in the following snippet:
For flash size of different devices please refer to the Table 1 and Table 2 from TLE987x User Manual.
Please let us know if you have further questions.
Thank you
Best Regards
Raj Chaudhari
Raj_C
Hi @Kathisai,
Thank you
Best Regards
Raj Chaudhari
Kathisai
Thanks for the quick response.
