RAM/flash memory usage for BLDC Foc sensorless code
Webinar: Integrated solutions for smaller, simpler low-voltage motor control design.
Join the webinar to experience!
Ghassen
10 replies posted 5 questions asked 25 sign-ins
Hi I am working on  bldc motors , and I used the software code exemple in keil library (FOC) to drive the motor in sensorless mode and I want to know   how much ressources it takes to run  this exemple code (RAM, flash memory and CPU)? is it possible to get these informations ? .
thank you .
Best regard.
RupakC
100 solutions authored 250 sign-ins 25 likes received
Hello @Ghassen
The TLE98xx family does not support the arm M Instruction Trace data (ETM), which is required for the uVision performance analyzer.
To analyze the runtime of a function, you can toggle a GPIO and check the timing of execution.
RupakC
RupakC
Hi @Ghassen
You may look into the following content for information on the resource allocation :
https://developer.arm.com/documentation/ka004381/latest
https://www.keil.com/support/man/docs/bl51/bl51_ln_mapfile.htm
You will find the .MAP file for the example codes in
Tle9879_evalkit\Boards\Infineon\TLE9879_EvalKit\BLDC_SENSORLESS_FOC_EXAMPLE_TLE987X\Listings
A view of the .MAP file is given below:
I hope This will help you to find out how much resources it takes to run the example code.
Thanks and Regards
RupakC
Ghassen
Hi @RupakC
Thanks a lot , that's so helpful ,but  is  there any way to measure processor usage while running this program ?
Best regards.
RupakC
Hi  @Ghassen
Please use the performance analyzer feature in Keil uvision. For details on the performance analyzer, please find the related document (page no. 105):
https://www.keil.com/product/brochures/uv4.pdf
I hope this helps solve your query. Please let me know if you need any other help.
RupakC
Ghassen
Hi @RupakC
Thanks for the suggestion , I tried to use performance analyzer  in keil but when I start the debug session and run the program nothing is displayed on the performance analyzer window , I mean all the modules statistics stay at 0 % and nothing evolve , do you know what is the problem ?
here an attached screenshot of the problem.
Thank you .
RupakC
Hello @Ghassen
RupakC
