User18667
How am I able to utilize the automatic rotational speed measurement and commutation control for block commutation that is a feature of the TLE 9879? Is there a code that will represent the "current" RPM of the motor? How can I use this feature? Please help!
Fiz
First solution authored Welcome!
Hello wskeller,
if you are using the block commutation example using BEMF you can use the function: uint32 Emo_GetSpeed(void)
This will return you the actual motor speed.
Best,
Fiz
User18667
Hi Fiz,
yes, I saw on the code.
Thank you.
