User18688
Dear all,
I'm trying to use the TLE9879 Eval Kit to drive a 24V BLDC motor.
However, every time I increased the voltage of DC power to be more than 5V, over-current protection is generated, which means the DC power cuts off itself.
The board should be able to handle 24V. What could the problem be?
Fiz
First solution authored Welcome!
Hello Rayking,
Which code are you using with the TLE9879 Evalkit?
Is the the overcurrent detected by the power supply or by the TLE9879?
Best,
Fiz
