How to use MosFet turn on characteristics to suppress in-rush current
Webinar: Integrated solutions for smaller, simpler low-voltage motor control design.
Join the webinar to experience!
RLGeorge
10 likes given 10 questions asked 25 sign-ins
Is there a white paper that clearly defines how to use MosFet turn on characteristics to suppress in-rush current?
Design is similar to the TLE9853 Eval board, H-bridge with larger Mosfet's.
With simulated inductive load we can control the current.
When testing an actual motor we experience an inductive in-rush current exceeding the pulse rating of the MosFet.
Micro TLE9853QX
MosFet IAUA250N04S6N005
Partial schematic attached.
Sahil_K
First like given 100 solutions authored 250 sign-ins
Hi @RLGeorge ,
You can use the soft-starting method with soft-starting hardware to reduce the inrush current.
Sahil Kumar
Sahil_K
Hi @RLGeorge ,
Sahil Kumar
