Webinar: Integrated solutions for smaller, simpler low-voltage motor control design.
Join the webinar to experience!
Omicron1314
10 sign-ins First reply posted 5 sign-ins
I want to creat the tab in config wizard as following picture shows. What should I do?
Raj_C
500 replies posted 50 likes received 250 replies posted
Hi @Omicron1314,
For the above example of Block Commutation Motor Parameter tab, please refer to the 'BC_Motorcontrol.xml' file in the following directory of the example code.
You can create your custom xml for the custom tab. We can not provide any guideline or recommendation for creation of this file.
Thank you
Best Regards
Raj Chaudhari
Raj_C
Hi @Omicron1314,
Thank you
Best Regards
Raj Chaudhari
