Aug 14, 2020
04:05 AM
Aug 14, 2020
04:05 AM
Hello ,
I am using TLE9879 evaluation board's example code -"BLDC_SENSORLESS_FOC_LIN_EXAMPLE_TLE987X". I have just modified the controller version as I am using tle9877 controller.On board we dont have external OSC or crystal.
My controller tle9877 is not working without debugger. When I flash the code then only my code works once, when I reset the controller it stops working.
When controller is reseted it take 20mA current, it means that controller is alive as it is taking current.
When I debug the code it works , when I flash the code (only by enabling reset and run) then it works. But as I reset the controller or power cycle it , it stops working.
I think after reset my code is not reaching to main() or reset_handler is not getting called.
please suggest me solution.
04:02 PM
Sep 28, 2020
04:02 PM
Hi Sagar,
Do you got solution for this issue? can you suggest me?
Oct 02, 2020
01:00 AM
Oct 02, 2020
01:00 AM
Hi sagar,
this sounds like an issue with your WDT or an invalid NAC value. Please double check.
