Webinar: Integrated solutions for smaller, simpler low-voltage motor control design.
Join the webinar to experience!
AmolKoli
Level 4
Level 4
First solution authored 10 questions asked 50 sign-ins
Hello ,
When we installed Config Wizard for MOTIX MCU, the Config Wizard option in Tools menu of Keil was not automatically added.
We had to configure it in the Customize Tools menu options explicitly:
As per the Getting started guide the Config Wizard should automatically be added in Tools once all settings are done.
Also for some members(different location) the procedure worked as expected.
Why did it need configuration on my Keil?
LinGuohui
500 replies posted 50 likes received 250 solutions authored
This dialog should be popup every time when you startup the config wizard tool if it doesnot add to Keil.
Some unknown reasons, such as PC software environment, may lead to this problem. This is why we provide a second way to add this tool to keil.
LinGuohui
Hello @AmolKoli
For install Config Wizard , You can refer to Software_and_Toolchain_for_MOTIX , 3.4 How to integrate the Config Wizard for MOTIX™ MCU into Keil uVision.
Yes, the Config Wizard option in Tools menu of Keil can be automatically added. If the Config Wizard notices on startup that a Keil µVision 5 is installed on the system, it asks to integrate itself into the Keil develop environment.
Thank you for your response.
WE followed the document for integration, but we did not get the "Keil uVision 5 Integration" popup.
And hence we had to manually add Config wizard to Keil.
Want to know why for system the popup does not appear. Thanks
LinGuohui
