Webinar: Integrated solutions for smaller, simpler low-voltage motor control design.
Join the webinar to experience!
AmolKoli
Level 4
Level 4
First solution authored 10 questions asked 50 sign-ins
I can see some "LDCTool" in sample code for TLE987x - BLDC with HALL and LIN.
Is this tool not a part of current toolset for TLE987x? Since there are no application notes, it is difficult to update LIN configuration without a auto codegen tool.
Sahil_K
First like given 100 solutions authored 250 sign-ins
Hi @AmolKoli ,
Unfortunately, this LDC utility is not part of the TLE987x toolset. However, please refer to the lin_hal_init_uart() function in the lin_hal.c file for information on various LIN settings. Please refer to section 19.6 'LIN Support in UART' and section 20 'LIN transceiver' in the user manual for further details about LIN.
Kindly let us know if you need any support in changing the configuration settings for LIN.
Sahil Kumar
Sahil_K
Hi @AmolKoli ,
Sahil Kumar
AmolKoli
Level 4
Level 4
Thank you for your response Sahil.
I would like to keep thread open for support on the configuration settings further!
