Hello everyone,
I installed, as in the "Getting Started for MOTIX™ TLE986x/7x" Manual the following applications:
1) Keil µVision5
2) Infineon developer center and inside it the config wizard for TLE987x
3) Segger Driver
4) µVision5 Pack installer for TLE987x
After all, I wanted to start the config wizard, but I get the following messages:
The config wizard is obviously not integrated in the Keil IDE, but I have installed all the parts as described. What is wrong?
I use Win10 on a ThinkPad Yoga370 with latest updates.
Hi @BR712,
Please, refer to the 'Getting Started with Keil µVision5' section of the Getting Started with TLE986x/7x Evalboards and Evalkits document (Page No. 21) for the integration of the Config Wizard to the Keil.
Please, let us know if you need further support.
Thank you
Best Regards
Raj Chaudhari
Hi @BR712,
Thank you
Best Regards
Raj Chaudhari
Thank you, that helped.
