CAN I use j-scope on TLE9879 Evalkit with onboard XMC j-link?
Webinar: Integrated solutions for smaller, simpler low-voltage motor control design.
Join the webinar to experience!
nemo_jun
First like received 50 sign-ins 25 sign-ins
I just bought a TLE9879 Evalkit to evaluate BLDC motor control. And I want use J-scope to monitor the variables of FOC demo. I download the j-link V7.82, but the j-scope didn't work.  Is my Evalkit onboard XMC j-link inmatch with the j-link driver or something else wrong?
LinGuohui
500 replies posted 50 likes received 250 solutions authored
Hi @nemo_jun
Onboard XMC JLINK is available for J-Scope.
Which Sampling Source do you used ? RTT or HSS.
For HSS source, you should add project file. And on board JLINK sampling rate is limited to 50Hz.
For RTT source, you shoud add J-Scope RTT code on your project.
LinGuohui
Hi @nemo_jun
