I just bought a TLE9879 Evalkit to evaluate BLDC motor control. And I want use J-scope to monitor the variables of FOC demo. I download the j-link V7.82, but the j-scope didn't work. Is my Evalkit onboard XMC j-link inmatch with the j-link driver or something else wrong?
Hi @nemo_jun
Onboard XMC JLINK is available for J-Scope.
Which Sampling Source do you used ? RTT or HSS.
For HSS source, you should add project file. And on board JLINK sampling rate is limited to 50Hz.
For RTT source, you shoud add J-Scope RTT code on your project.
Hi @nemo_jun
