User16953
I have an issue for GH / GL output waveform as below picture.
The GH1 output level has step waveform by dead time of GL1 output.
Which point should i check?
Please advise.
3604.attach
Fiz
First solution authored Welcome!
thank you for your post and your interest in our products!
To help you I would need some more information:
1) What is your supply voltage?
2) What load are you driving?
3) Are you jumping with your PWM? (from a high to a low duty cycle)
Best,
Fiz
