Webinar: Integrated solutions for smaller, simpler low-voltage motor control design.
Join the webinar to experience!
yuhplc
First question asked Welcome!
Dear Mr./Mrs./Ms,
   I am a beginner of  uIO-Stick v2. In the  uIO-Stick v2 user guide, the  Pin 6-Vs is described as follows:
Pin 6 - VS: can either be driven from the implemented boost converter on the uIO-Stick v2 (+12 V) or can
be overridden by an external supply, for example the supply of the target device. This pin is also used to
internally drive the LIN transceiver available on the uIO-Stick v2.
    I am puzzled on " (Vs) can be overridden by an external supply, for example the supply of the target device". Does the Vs pin can be connected to the supply of the target device ? If so, do the internal supply and the external supply have collisions?
  best wishes,
LinGuohui
500 replies posted 50 likes received 250 solutions authored
Hi @yuhplc
For VS power supply on uIO-Stick v2, It can be enabled/disabled by yourself.
LinGuohui
Hi @yuhplc
