MOTIX™ Bridges
User22227
New Contributor
Sir,
This is Chamarthi from India. I am using the BLDCSHIELDIFX700T for controlling the BLDC motor. I observed the current sense signal (IS) in the board is having an offset error.
Please share with me, if there is any method or algorithm for compensating the offset in the IS signal.
Thank you in advance
