MOTIX™ Bridge
User22227
This is Chamarthi from India. I am using the BLDC Shield IFC007T board for controlling the BLDC motor. While developing the current controller, I observed there is an
offset existing in the IS pin for zero current. We want to know the method to compensate the OFFSET in the signal IS of the board. Please share with us if there is any
possible compensation method in the control algorithm, which would be easy and handy for us.
with regards,
Chamathi.
MMA
Moderator 10 sign-ins 5 replies posted 5 sign-ins
you are right, the IS current consist of an offset and the sense current information.
The offset correction isn't implemented.
You may want to measure the offset via the ADC before you run the software and substract this value later on.
You may also check on github:
https://github.com/Infineon/IFX007T-Motor-Control
MMA
mma
User22227
Is there anyone who knows the way to remove the offset error in the application code?
please share the information
MMA
MMA
mma
User22227
Thanks for the reply Markus
I am doing experiments in resolving this issue, if I know I can share you.
MMA
Hi Sivaram,
would be great to share your experience in the forum.
Markus
mma
