Join us at PCIM Europe [10-12 May]. Get free access to virtual booth with myInfineon registration. Learn more
MOTIX™ Bridge
User22201
Can BTN7030-1EPA recover from undervoltage on Vs?
User19575
First solution authored
Between VS(OP) and VS(UV) the undervoltage mechanism is triggered.
If the device is operative (in Active mode) and the supply voltage drops below the undervoltage threshold VS(UV), the internal logic switches OFF the output channel.
As soon as the supply voltage VS is above the operative threshold VS(OP), the channel is switched ON again with a hysteresis of VS(HYS).
User19575
Top labels
