Join us at PCIM Europe [10-12 May]. Get free access to virtual booth with myInfineon registration. Learn more
MOTIX™ Bridge
User21997
Is DC Link capacitor required and how to calculate it’s value?
User19575
First solution authored
Yes it is required,
It is used for filtering voltage spikes on the battery line. This electrolytic capacitor is required to keep the voltage ripple at the Vs-pin low during switching operation.
It is usually recommended that the voltage ripple at the Vs-pin to the GND-pin is kept below 1 V (∆VS) peak to peak. The value of CVS must be aligned accordingly.
The layout is very important too. , this capacitor should be positioned with very short wiring close to the NovalithIC™ Lite chip. This must be done to keep the parasitic inductors of the PCB-wires as small as possible
For more details please refer to NovalithICTM half-bridge family BTN89xx.
User19575
Yes it is required,
Top labels
