mario1
5 sign-ins First like given First reply posted
Could you tell me please if IPDD60R075CFD7 can be used in automotive projects, because in the datasheet it appears as a potential application, but it seems that the part was not validated accordingly?
Could you recommend me please, another part instead?
Marius
G_Anshika
250 replies posted 100 solutions authored 250 sign-ins
Unfortunately, there is no validation document available as of now.
But if you intend to use CoolMOS CFD7 in your application, we have automotive-qualified CFD7 for this i.e. CFD7A,where A stands automative qualified.
I am attaching two links for your reference:
1. For detailed portfolio of Automative Qualified MOSFETs-
Infineon_Automotive MOSFETs
2. I filtered the MOSFETs on the basis of their similarity with parameters of IPDD60R075CFD7 such as Rds(on) and Vds-
Filtered List for CFD7A
Please select accordingly as per your application ratings.
Let me know if you need any more support. Happy to help.
Anshika
G_Anshika
Thankyou for posting on Infineon Community.
1. IPDD60R075CFD7 can be used in automative applications. CoolMOS 600V CFD7 has the necessary performance to target the EV charging market for off-board chargers or charging piles.
2. Can you please tell about your application requirements so that we can guide you better?
Thanks and Regards,
Anshika
Hello Anshika,
Thank you for your feedback. Could you tell me please, is there any updated datasheet that shows the AEC qualification?
I would like to use it in a DCDC on the HV side.
Marius
G_Anshika
Anshika
