Laney
5 sign-ins First reply posted First like given
when i applied for free trial of lifetime eastimation, it showed errors,how to solve this problem
L
Guru_Prasad
250 replies posted 100 solutions authored 25 likes received
Dear @Laney
Please follow the below procedure
Step:1 Please select the service showed topologies
Step-2 Please select the device provide parameters for your topology ,
step-3 Run the simulation you can get below image and results
For more details Please use below document.
https://www.infineon.com/dgdl/Infineon-IPOSIM_Lifetime_Estimation_service-UserManual-v01_00-EN.pdf?f...
Note: Please let me know if this is not working for your topology
Thank you
Guru
Guru_Prasad
Dear @Laney
Greetings!
May I know for which product you are calculating lifetime?
Thank you
Guru
Dear Guru,
 The product is IPOSIM Lifetime Estimation service, the error as follows:
Guru_Prasad
Dear @Laney
Thank you
Guru
