interleaved active clamp flyback converter
User18454
First question asked
as per the figure we provides a dc voltage as a input to the interleaved active clamp flyback converter block, provide a PWM signal to the MOSFET which is in interleaved block for switching purpose. PWM signal is generated by the microcontroller which has a fix frequency 57 KHz and 50 % duty cycle then we got a output like triangular waveform. actually we will need a output like a given figure so which type of PWM output will be provided to the switching MOSFET, so we got proper output of the interleaved active clamp flyback converter.
Abhilash_P
50 likes received 500 replies posted 250 solutions authored
To get the output as shown in the figure (fully rectified sine wave), please follow the steps,
1) Use a proper filter circuit at the output (preferably LCL).
2) The PWM duty has to varied from minimum to maximum to and maximum to minimum at every each half cycle.
Abhilash P
Abhilash_P
Abhilash P
