- Email to a Friend
1. sinking current to ground, Lithium battery discharge (29V) ,15A current.
2.current fixed
3.Current accuracy within 5%.
4.output:Lithium battery 29V, MAX30V
5.transistor:used MOS IRF540 before, but cannot reach 15A。
If you have a better recommendation circuit or better information,I would appreciate it。What should I pay attention to in the design?
Thank you !
- current source
- Email to a Friend
Thank you for posting on Infineon Community.
Regarding your query, can you please tell me for what application you want to design a current source so that I can recommend you a MOSFET as per the application qualification?
Also, please use this link for finding Infineon products :https://www.infineon.com/cms/en/tools/
Thanks and Regards,
Anshika
- Email to a Friend
Thanks and Regards,
Anshika
