- Email to a Friend
- Email to a Friend
The board by default has Constant-Voltage Constant-Power curve programmed. This curve is provided in the App Note that Krupashankar shared earlier. CC mode can not be achieved directly using GUI, but you will have to modify the source code which is also provided to you to modify and implement the charging profile you need.
Pranava
- Email to a Friend
Hi @User20393,
Yes, the Constant current mode is supported in EVAL_3K3W_BIDI_PSFB.
Please refer to the application note: https://www.infineon.com/dgdl/Infineon-Application%20Note%20EVAL_3K3W_BIDI_PSFB%20AN_1809_PL52_1809_...
Krupashankar
- Email to a Friend
Hi Krupashankar
Thanks very much for your advice
Don't get me wrong
I'm not good at coding.
I'm not sure whether GUI user interface can support CC output or not?
if not
pls recommend appnote how to do
- Email to a Friend
Pranava
- Email to a Friend
Hi
As provided sourcfe code need to be modified.
I wonder if you give me some idea how to modify it.
Thanks in advance
- Email to a Friend
Please contact nearest Infineon FAE and get help in modifying the sample code.
Pranava
