XMC4200 EVAL_3K3W_BIDI_PSFB can support CC output?
User20393
Distributor
50 sign-ins 10 replies posted 10 questions asked
Hi
Pranava_YN
The board by default has Constant-Voltage Constant-Power curve programmed. This curve is provided in the App Note that Krupashankar shared earlier. CC mode can not be achieved directly using GUI, but you will have to modify the source code which is also provided to you to modify and implement the charging profile you need.
Pranava
Krupashankar
500 replies posted 50 likes received 25 likes received
Hi @User20393,
Yes, the Constant current mode is supported in EVAL_3K3W_BIDI_PSFB.
Please refer to the application note: https://www.infineon.com/dgdl/Infineon-Application%20Note%20EVAL_3K3W_BIDI_PSFB%20AN_1809_PL52_1809_...
Krupashankar
User20393
Distributor
Hi Krupashankar
Thanks very much for your advice
Don't get me wrong
I'm not good at coding.
I'm not sure whether GUI user interface can support CC output or not?
if not
pls recommend appnote how to do
Pranava_YN
Pranava
User20393
Distributor
Hi
As provided sourcfe code need to be modified.
I wonder if you give me some idea how to modify it.
 Thanks in advance
Pranava_YN
Please contact nearest Infineon FAE and get help in modifying the sample code.
Pranava
