Vin RMS calculation in PFC stage of 3.3kW on board charger
Rakesh_rp
First solution authored 10 replies posted 10 questions asked
I have a doubt in  3.3kW PFC stage  in the given Infineon code for 3.3kW PFC demo board.  The VIN AC RMS voltage is calculation is done by using a digital filter . The Vin sensed ADC reading is  sampled at 30kHz.   The digital filter  function is called every 2.5kHz. The output of filter is considered as average AC voltage . This average voltage is multiplied with 1.111 to get  RMS  AC voltage.  I want to know the cutoff frequency  and  type of filter used.
Below the equation used in code  for filter.  g_U_in   is the ADC reading for Vin Ac sense.
Pranava_YN
100 likes received 500 replies posted 250 solutions authored
Hi Rakesh,
Sorry for the delay in responding. The equations you refer to are the back-to-back low pass filters. The filter factor used (ZK_UIN = T0/T = 1041) is defined in defines.h
http://techteach.no/simview/lowpass_filter/doc/filter_algorithm.pdf  you can refer to this.
Pranava
Pranava_YN
Can you please share the source code you are referring to?
Pranava
Rakesh_rp
Thanks for replying,
The source code is attached please check.
Please provide  a solution soon.
RAKESH
Pranava_YN
Hi Rakesh,
Pranava
