Hello ,
BSC077N12NS3 used by Inverter customer in H-Bridge converter and facing intermittent failure .
Customer has requested for Vds breakdown voltage test report for BSC077N12NS3 to understand tolerance with this device .
Thanks & regards,
Harsha
- LV Mosfet
Hello Harsha,
The requested data cannot be shared on Community as it is a public forum. Request you to create a case under MyCase system or submit a request via our direct channel https://www.infineon.com/tac.
Meghana
Hello Harsha,
Meghana
Hi harsha
seeing the datasheet what i can tell u is this is a 120V mosfet at nominal temperature the
minimum voltage it can tolerate is 114V at negative temperature.
