- Email to a Friend
A few years ago, I read that Infineon was going to develop an over-current blocking fet.
This was to be a high voltage, high current circuit breaker based on a high current “lambda diode” and a HV cascode depletion mode mosfet.
See for example:
https://www.electronicsweekly.com/market-sectors/power/infineons-current-blocking-fet-2014-07/
Does anyone know if anything came of this or whether it is still in development, or even if now exists by some other name ?
- Email to a Friend
Hi Derek,
Regarding the article you mentioned in the query, eventually, we didn't follow up on that and this featured product does not exist in our portfolio.
But one approach for an active solution might be using the desat-functionality of a gate driver which is normally used for short circuit detection of a power switch like a power MOSFET or an IGBT.
Hope it helps.
Anshika
- Email to a Friend
Hello @Inf1 ,
Thank you for posting on Infineon Developer Community.
Regarding your query, allow me some time to find more information about it. In the meantime, can you please tell me for what specific ratings and application are you looking for ?
Anshika
- Email to a Friend
Hi Anshika,
Thank you for your quick reply.
I would be looking for a normal operating voltage of up to 1000V so it would need to withstand a bit more than that.
The current trip would be around 1A.
Kind regards,
Derek
- Email to a Friend
Hi Derek,
Thanks for your response.
Are you going to use it as a part of an automotive application?
Currently, we have IGBTs and SiC MOSFETs that supports voltage rating above 1000 V range.
Please have a look and let me know if you need any help.
BR,
Anshika
- Email to a Friend
Hi Derek,
Hope it helps.
Anshika
