- Email to a Friend
Hello
- Email to a Friend
In that case, you can disable the OVP/UVP by doing the following,
You can try commenting out the definitions of UVP_ON() and UVP_OFF() as well as OVP_ON() and OVP_OFF() present in controller.h. You can also comment out the ovp_uvp_ctr() function as even that just handles OVP/UVP.
Pranava
- Email to a Friend
Would someone reply on this ?
I don't have any idea how to proceed further.
- Email to a Friend
There are no inbuilt macros defined to ENABLE and DISABLE UVP and OVP protection.
You can try commenting out the definitions of UVP_ON() and UVP_OFF() as well as OVP_ON() and OVP_OFF() present in controller.h . However, it is recommended to not disable OVP and UVP protections but use an inrush limiter instead.
Pranava
- Email to a Friend
Hello Pranava
If I comment out the ovp_uvp_ctr() in main.c, will it turn off the OVP and UVP protection of the evaluation board.
I know it is not recommended to disable OVP and UVP protections. But the reason why i m turning it off.
Reason:- A BLDC motor is connected at the output of the Evaluation board EVAL_3K3W_LLC_HB_CFD7, So when the bldc motor is rotating EVAL_3K3W_LLC_HB_CFD7 working fine but when we stop the rotation of the bldc motor the Evaluation board EVAL_3K3W_LLC_HB_CFD7 shuts down and goes into UVP/OVP protection.
It is false triggering, if you can give another option to prevent this shut down it'll be helpful.
- Email to a Friend
Any suggestions on this ?
- Email to a Friend
May I know the reason for choosing EVAL_3K3W_LLC_HB_CFD7 to drive a BLDC motor?
You can look at our iMotion range of products that are custom made for motor control applications with sophisticated algorithms - https://www.infineon.com/cms/en/product/power/motor-control-ics/imotion-integrated/
Using an inrush current limiter is the only way I can think of to overcome this issue. But I recommend you to look in to the iMotion products first.
Pranava
- Email to a Friend
Hello
We are doing long power transmission so to overcome the power loss we are using the EVAL_3K3W_LLC_HB_CFD7 to drive a BLDC motor.
We have used inrush limiter also but inrush limiter has several disadvantages-
1. Voltage drop in the initial starting of the operation.
2. Frequent operation is not possible because we have to wait it to cool down first.
3. Very high temperature of the shunt limiter.
So these reasons affects the operation
So only option we have is to turn off the OVP/UVP protection.
So as I previously asked commenting out the ovp_uvp_ctr() in main.c will it turn off the OVP/UVP protection?
Ashwani
- Email to a Friend
Pranava
- Email to a Friend
Thank you Parnava
One more thing i want to ask about this evaluation board
Problem :- When we switch on the converter It is giving the output voltage and giving normal operation but when we switch off converter and again switch on then it doesn't turn on.
But after waiting 1 min if we switch it on again then it turn on what is the reason behind this.
Ashwani
