tex
First like given 10 sign-ins First reply posted
PN#BSZ067N06LS3GATMA1: Checked the actual thickness of the device (1.03mm) which is out of the range as following the dimension of datasheet (Max 1.00). Is it normal/acceptable? or some amendment can be found? Thanks.
Jingwei
250 sign-ins 10 likes given 100 solutions authored
Hi tex,
please check the flatness of this chip. It is 0.05mm in the datasheet. 0.03mm is inside.
Thanks and BR,
Steven
Jingwei
Hi tex,
could you give your measurement picture of the actual thickness of the device (1.03mm)?
Thanks and BR,
Steven
Jingwei
Hi tex,
Thanks and BR,
Steven
