Thermal Spice model subckt in irf135b203 spice model
User21717
First question asked
So this question likely id's me as newbie...but is there an appnote on the use of the spice thermal model subcircuit that appears to be appended to the end of the irf135b203 spice model.
thanks in advance
cmoses
Abhilash_P
50 likes received 500 replies posted 250 solutions authored
Please refer the following appnote to know more about different models available,
https://www.infineon.com/dgdl/Infineon-ApplicationNote_PowerMOSFET_SimulationModels-AN-v01_00-EN.pdf...
In the spice thermal model sub circuit, values from Rth1 to Cth6 are thermal network parameters.
Please refer the following link for accurate connection of thermal impedance network,
https://www.infineon.com/dgdl/Infineon-Application_note_Dynamic_thermal_behavior_of_MOSFETs-AN-v01_0...
For further understanding of thermal network parameters, please refer the following appnote,
https://www.infineon.com/dgdl/Thermal%20Modeling.pdf?fileId=db3a30431441fb5d011472fd33c70aa3
The basics of thermal equivalent circuit models can be found in 2nd chapter of the following appnote,
https://www.infineon.com/dgdl/Infineon-Thermal_equivalent_circuit_models-ApplicationNotes-v01_02-EN....
Abhilash P
Abhilash_P
Abhilash P
