MS_19060803
Distributor - TED (Japan)
25 likes received 25 solutions authored 10 likes given
Hi all,
Please tell me about the negative voltage of the 1200V CoolSiC MOSFET.
Regarding the gate voltage, the datasheet says please refer to Application Note AN2018-09.
 In the case of IMW120R350M1H, M1H before date code 2213 is the following dat.
M1H after date code 2213 is the following data. Is my understanding of this correct?
MS
Santhoshkumar
25 solutions authored First like given 50 replies posted
Dear @MS_19060803
Greetings from Infineon Technologies!!
Good day!!
Yes you are correct. After M1H datecode 2213 i.e., after 13th calender week of 2022 Vgs has improved from -7/23 to -10/23.
Please let me know if you have any further queries.
Thanks & Best regards
Santhosh Kumar
Santhoshkumar
Dear @MS_19060803
Greetings from Infineon!!
Thanks for posting in the Infineon Community
I am checking internally. I will get back to you soon. Please provide us sometime.
Thanks & Best regards!
Santhosh Kumar
MS_19060803
Hi all,
Thank you for your support.
MS
Santhoshkumar
Dear @MS_19060803
Good day!!
Santhosh Kumar
