AkUm
Distributor - Macnica (Japan)
10 replies posted First solution authored 100 sign-ins
The document has a graph of (Figure 9 Time evolution of PBTI at 200°C using a stress bias of +25 V.), but does this also occur when the temperature is below 100°C, etc.?
Please provide a graph of temperature-dependent characteristics, if any.
Also, how much do gate threshold voltage and ON resistance change with DC BTI?
https://www.infineon.com/dgdl/Infineon-Reliability_of_SiC_power_semiconductors-Whitepaper-v01_02-EN....
Dipti_Kiran
250 sign-ins 10 likes received 50 replies posted
Hi @AkUm ,
May I know why you need this data?
Dipti
AkUm
Hi, @Dipti_Kiran ,
As a system, we have a need to make the FETs always ON in standby mode.
In this case, there is a concern that applying a DC bias to the gate may cause DC BTI, which changes the threshold voltage and ON resistance.
AkUm
Dipti_Kiran
Hi @AkUm ,
I will request you to create a case under “Product qualification” under "Sales Support" track in the Mycases portal. Please find the attached leaflet, it will guide you to create a case.
Please let me know, if you need any help in case creation.
Dipti
AkUm
Hi, @Dipti_Kiran ,
I have created a case. IFX-240123-1208776
Please check it out.
AkUm
Dipti_Kiran
Hi @AkUm ,
Thank you for creating the case in case management tool.
The responsible team will take care of your request. Please follow the case in MSD tool.
Dipti
