Technical information request for IPC70N04S5-4R6
Alfredo_Herrera
First question asked Welcome!
Hello Infineon team,
Good morning. Could you please help me to get some data?
Does the IPC70N04S5-4R6 meet 85C/85% relativity humidity 1000 hour test requirement? or similar HAST/JEDEC test?
Do you have micro strain rating of this component?
Thank you in advance,
Alfredo Herrera
Hardware Engineer Kostal
Meghana
50 likes received 100 solutions authored 10 likes given
Hello Alfredo,
Apologies for the delayed response. Below are the comments for your query.
1.Does the IPC70N04S5-4R6 meet 85C/85% relativity humidity 1000 hour test requirement? or similar HAST/JEDEC test?
- Yes. IPC70N04S5-4R6 meets the requirement of 85C, 85% relative humidity,1000hr test requirement and is fulfilled by H3TRB test.
2. Do you have micro strain rating of this component?
- Are you referring to the strain measurement data which is done on the component when its mounted on the PCB? If yes, then this refers to the second level reliability test, which is done at the customer side. Hence we, unfortunately, cannot support you in the same.
Kindly let me know if you require further support related to this topic.
Meghana
Meghana
Hello Alfredo,
Meghana
