nsyed
Jul 28, 2021
08:55 AM
- Email to a Friend
I am looking at the datasheet of TLE7181EM, Rev 1.2 2019-03-14.
The Table 7, PWM/DIR interface normal operation does not makes sense
When DIR is se to 1 - All HighSide and Low-Side switches are turned OFF.
I believe there is a typo in this table and the DIR & DRVDIS table columns are swapped. Can anyone confirm if this is the correct ?
06:23 PM
- Email to a Friend
Hello Nadeem,
It was confirmed that the two columns are swapped and that it is a documentation mistake.
The new and corrected document is now in the process of being finalized.
Therefore, it will soon be published.
Thank you for catching this error.
Pablo
Pablo
07:00 PM
- Email to a Friend
Hello Nadeem,
I went through the table you referred to, and as you suggested, the DIR and DRVDIS columns seem to be swapped.
I will check internally about this and get back to you.
Once I have the confirmation, I will let you know.
Thank you for noticing this possible mistake.
Pablo
Pablo
nsyed
Jul 29, 2021
02:28 PM
- Email to a Friend
Appreciate your help !!! Please let me know when you have an update.
06:23 PM
- Email to a Friend
Hello Nadeem,
Pablo
Pablo
nsyed
Aug 03, 2021
08:53 PM
- Email to a Friend
Pablo Elosegui Garcia wrote:
Hello Nadeem,
Pablo
Thank you so much !! Appreciate your help !!!
