KUOWENYUNG
25 replies posted 100 sign-ins 50 sign-ins
Hello IFXer,
Since trench gate SIC MOSFET has narrow nagative voltage window compare with planner gate SIC MOSFET.
we are care about the gate driver whether build in miller clamp and use zero voltage to turn off SIC MOSFET.
but there is all half bridge topology need use miller clamp function? please help advise.
hard switch: buck, boost, totem pole
soft switch: ACF flyback, LLC, phase shift full bridge
vigneshkumar
250 sign-ins 50 solutions authored 100 replies posted
False turn -ON could happen in Half bridge circuit also.
Miller Clamp is always good to avoid return on especially devices with a low threshold. However, return on can be avoided in normal operation with the RC circuit.
Vignesh kumar
vigneshkumar
Hi ,
Thanks for posting on Infineon community,
Do you want us to suggest devices?
Vignesh kumar
Hi Sir,
just confirm that all half bridge circuit are need miller clamp function gate driver?
vigneshkumar
Vignesh kumar
