Hi Team,
Customer had IMW120R060M1H to replace wolfspeed C2M0080120D.
Customer have questions below question would like to clarify.
- From the graph below, the gate resistor is 100ohm. The negative current is around -0.8A. However, the MOSFET is very hot. They have tested with 10ohm gate resistor, but the negative current up to -2.3A observed. Will negative current spike of 2.3A cause any reliability issue to the SIC MOSFET?
- What is the max negative current the SIC MOSFET can sustain?
- If the negative current will cause reliability issue, how to improve the ringing?
The brightness below refers to the load level. 100% Brightness = full load, 10% Brightness =light load
Customer is using flyback controller to drive the SIC MOSFET.
MOSFET Waveform (Ch1=Vds, Ch2=Vgs, Ch4=Ids)
Fig.1 : 100% Brightness
Fig.2 : 40% Brightness
Fig.3 : 30% Brightness
Fig.1 : 20% Brightness
Fig.4 : 10% Brightness
Schematic (Output 350W 500V 700mA)
Thank you for posting at Infineon community.
1) Can you please share the complete schematics especially gate circuit and secondary side circuit.
2) May I know why did you put C3 of 10Pf .
BR,
AZIZ HASSAN
BR,
AZIZ HASSAN
Can you please update the status.
BR,
AZIZ
Any updates please.
BR,
AZIZ
