What is the future for EV based industry using SiC based diodes and MOSFETs?
What are some advantages of Silicon Carbide based components over a general component.
Silicon Carbide
- silicon carbide
Hello @PayalChaturvedi
Thanks for posting the question in Infineon community
SiC's(MOSFET and Diodes) are having below mentioned advantages
1)SiC devices can have higher current densities compared to Si
2)SiC devices can operate at higher frequencies so that the losses can minimize hence efficiency can improve.
3)Higher Power density reduced cooling requirements and lower overall system cost.
In the EV industry we need to use Power electronics for EV charging stations, EV power train inverters, Onboard
chargers, compressor inverters. All these products will replaceable SiC devices. In Infineon, we have Sic Based
solutions for EV products some of the reference material and relevant pages are given below
Please click here for SiC based topology design for EV
Please click here for SiC based EV fast charging
Please click here for SiC products
Please let me know if you need any help.
Guru Prasad
Guru Prasad
