MOSFET (Si/SiC) Forum Discussions
MartinSquella
First like given First reply posted 5 sign-ins
Dear technical support team of Infineon™,
I am writing to you because I bought a Eval-M5-E1B1245N-SiC Evaluation Board for tests under laboratory conditions and unfortunately the FS45MR12W1M1_B11 SiC MOSFET power module burned during such tests. Not only the power module burned but also the PCB around.
I intend to buy a new FS45MR12W1M1_B11 power module from Infineon™ to repair the inverter, but for that I need the Gerber-files and Layout design of the PCB of the Eval-M5-E1B1245N-SiC. In the event that it is not possible to deliver the Gerber-files and Layout design of the entire evaluation board, at least I request the part surrounding the power module (whose image is attached at the end of this message). Especially considering that the PCB consists of four layers.
Last but not least, I would like to ask you what is the glue used in the four aluminium capacitors (B43630A9128M000), since I need to know its nature in case I need to replace the capacitors during the repair.
Thank you in advance,
Kind regards,
Martín Squella
Please raise your request on Infineon web page under my case section.
Below is the link for the same.
https://www.infineon.com/cms/en/
Please click on my infineon, there you will get a option of my cases in drop down. Please register there and post your query there.
BR,
AZIZ
AZIZ_HASSAN
25 likes received 100 sign-ins 50 solutions authored
Since this data is not directly available on website, I request you to raise a request in my cases. There I can provide you the requested file. I hope you understand.
BR,
AZIZ
Hello AZIZ,
Thank you for answering me. I would like to take advantage of asking you where I can submit a request in "my cases", since I am new to the developer community.
Kind regards,
Martín Squella
BR,
AZIZ
