Regarding the label of IPD90P04P4-05
User22736
First question asked Welcome!
I found sometimes the label is printed with OptiMOS™ but sometimes it can not be found on the label,and this happens to many other part numbers, why is this?thx
Vishnu_Nambrath
50 solutions authored 100 replies posted 5 likes given
I assume that you are talking about the marking on the component. Some part numbers are with the label OptiMos, some are not.  As per the datasheet of IPD90P04P4, It is without OptiMos label on the part as shown below.
If you have seen this part with OptiMos label, Can you please share the image?
Vishnu Nambrath
