Ky-8086
Hello
Can  2 modules be connected in parllel to achive 22 kW, if yes, can you just help with any precausions or issues that might arise from such a configuration.
The second question, if you need to scale this design to achive 22 kW , can you recommend the part numbers and the new  resonant compnent values? and can you still us the same GUI and available source to control the new design for testing purposes , is that something you can support
Thank you
1211Shukla
100 replies posted 10 likes received 25 solutions authored
Hello @Ky-8086
Control card is having CAN communication so it is possible to establish communication among the boards for paralleling but the original algorithm does not have provision for parallelization and it needs to be changed for the same purpose. We will update you more in the following week.
Rishabh
Guru_Prasad
250 replies posted 100 solutions authored 25 likes received
Hello @Ky-8086
Thank you for posting your question in the Infineon community.
Noted your requirement. we are working on it. Please give us some time.
we will get back to you as soon as possible
Thank you
Guru
1211Shukla
Hello @Ky-8086 ,
The feasibility of 2x11kW boards in parallel is a tricky scenario, till date we did not have this use case. We need some more time to check it.
Thanks for your patience!
Rishabh
Ok. Thanks for the update.
is there any updates here ?
1211Shukla
Hello @Ky-8086
Rishabh
Ok, thanks , will be waiting for further updates
AZIZ_HASSAN
5 likes given 250 sign-ins 100 solutions authored
Since, the team is working on similar product, it may take some time. I request you to raise a new request after some days.
For now I would like to close the ticket.
Thanks and regards,
AZIZ
