User17756
First question asked First reply posted
Hey all,
is it mandatory to use -5V during turn-off? Can 0 V be used?
YUAN
First like received 10 replies posted 5 solutions authored
I believe you are asking the gate voltage window.
For the gate voltage, please follow the application note. 0V is recommend for the discrete devices.
https://www.infineon.com/dgdl/Infineon-Guidelines_for_CoolSiC_MOSFET_gate_drive_voltage_window-Appli...
YUAN
electricuwe
10 sign-ins First question asked 5 sign-ins
Also for the Easy modules 0 V can be used in case simplicity of the design has priority vs. switching speed. With a higher turn-on gate resistor the dV/dt can be reduced to a level that also modules - inspite of their longer internal and external gate connections - can be operated with 0 V. In some applications - like drives - dV/dt needs to be limited anyhow to avoid adverse effects on the machine windings and bearings.
Fränce
5 sign-ins 5 replies posted 10 questions asked
Dear YUAN,
I had a look at the application note AN2018-09 and i am not sure if the the IMZ120R030M1H is able to operate with a gate voltage of +18/-5. Is it safe to operate the device for a reasonable amount of time?
Could you please clarify?
YUAN
It really depending on the what is the reasonable time and the switching frequency. In the appnote, we translate the total switching events into a nominalized switching frequency. Please calculate the total switching events in your application, if your switching fsw * total designed operation time is smaller than 10k*10*365*24*3600, then 18/-5V(including undershoot) is OK. However, CoolSiC MOSFET is very robust against parasitic turn-on effects, we do not see the reason to have such low turn-off voltage.
