1. Output filter MG10000850 (Designator: L2). The specified value of the inductance in the document MG10000850 is different from the circuit.
ispn:32181:1:0
l1:314:1:0
MG100002271 can be ignored. This part number is given in the application note for L2 which will be changed as per BOM.you can follow the BOM part number MG10000850.
MG10000850 default value is 90uh and 20% tolerance is common. 72.5uH is possible.
Vignesh kumar
Thanks for posting on the Infineon community,
Output filter L2 is with MG100002271.
MG10000850 is not there in EVAL_3KW_50V_PSU
Vignesh Kumar
BOM says MG10000850
Please correct me if I am wrong
You are stating that MG10000850 is not 90uH.
Regrads,
Vignesh kumar
Could you please send the complete file?
Vignesh kumar
Vignesh kumar
Missing documentation MG100002271. Is there documentation?
Vignesh kumar
