Fränce
Moderator 5 sign-ins 5 replies posted 10 questions asked
I was wondering, is there a possibility to avoid parasitic turn-on without a negative voltage supply?
electricuwe
Moderator 5 sign-ins 25 replies posted 10 solutions authored
Hello, as the link provided in the previous reply seems to be dead, please see here:
https://www.infineon.com/dgdl/Infineon-Bodos_Parasitic_turn-on-Article-v01_00-EN.pdf?fileId=5546d462...
electricuwe
_Lisa
Good morning,
driving the SiC MOSFET with VGS,off = 0V and a 1EDI EiceDRIVER Compact with active Miller clamp will avoid a parasitic turn on.
Moreover, by eliminating the negative-voltage driving, the power losses of the driving stage can be reduced (~30% less, assuming VGS,off=-3V and VGS,on=20V) or for the same power losses, the VGS,on can be increased.
BR
_Lisa
User22602
First solution authored
Thanks for sharing this! This is really helpful! Please visit our sites also: canton carpet cleaning : canton concrete : canton handyman
User22409
electricuwe
electricuwe
