04:19 AM
- Email to a Friend
at the moment I'm creating a PCB design in Eagle. I want to use the IPT015N10N5.
To create a new device in Eagle I was looking for package information containing information about the pad sizes. The datasheet states the package as PG-HSOF-8-1. The prodcut page contains
a pdf "Application Note OptiMOS™ Recommendations for Board Assembly of PG-T(S)DSON Packages". In that pdf the named package is not listed. Therefore I'd like to know which package
from this pdf to use instead of PG-HSOF-8-1. Or were to find information for the PG-HSOF-8-1 package.
Benjamin
Benjamin
- ipt015n10n5
01:39 AM
- Email to a Friend
Hi Benjamin,
this link about the package P/PG-HSOF-8-1 (JEDEC: H-PSOF) may help you:
http://www.infineon.com/cms/packages/SMD_-_Surface_Mounted_Devices/P-PG-HSOF/P-PG-HSOF-08-1.html?__l...
Luxun
Luxun
01:39 AM
- Email to a Friend
Hi Benjamin,
Luxun
Luxun
