PL15, PL18 - Customer request of specific value ( λ0, λB) in FIT data
tommylee
5 sign-ins First question asked First reply posted
Dear colleagues,
Weve got the ask the Lambda value(λ0, λB) for two products as below from the customer (ATV ).
They want to get the Lambda value of the package as per TR 62380. You can refer the attached example about Lambda value of another product IAUA250N04S6N007 (ATV MOSFET) for example.
I checked the FIT data of two products in IFX intranet but there is no data of lambda there.
Would you help me get  these lambda value (λ0, λB)?
  1. BSZ15DC02KD : λ0, λB =??
  2. BSL606SN: λ0, λB =??
** Example: sTOLL FIT report of IAUA250N04S6N007
Shivam_P
100 replies posted 250 sign-ins 50 solutions authored
Hello @tommylee ,
For the requested data, may I ask you to create a MSD case with the customer details.
The detailed process is attached in the link below-
https://www.infineon.com/export/sites/default/en/about-infineon/company/contacts/support/images/Leaf...
Thanks & Regards
Shivam
tommylee
Hello ShivamPandey,
It is already solved.
If i need another help, i will create a MSD case later.
Thanks & Regards
Tommy
