PG-TDSON-8
MS_19060803
Level 6
Level 6
Distributor - TED (Japan)
25 likes received 25 solutions authored 10 likes given
Hi all,
Could you tell me the difference between PG-TDSON-8-33 and PG-TDSON-8-34?
MS
Meghana
50 likes received 100 solutions authored 10 likes given
Hello MS,
The last two digit of the package name indicates the version. Version update is done when there is a change in either package dimensions or package internal design change, or both.
In case of PG-TDSON-8-33 and PG-TDSON-8-34, there is no difference in the package dimensions, but they differ in the package internal design features. You may use either of them while designing your PCB.
Hope it is clear.
Meghana
Meghana
Hello MS,
Hope it is clear.
Meghana
