04:16 AM
- Email to a Friend
I downloaded the .lib file
* INFINEON Power Transistors *
* Level-0/1/3 PSPICE Library for CoolMOS Transistors C3A 800V *
* Version 271212
Where can I get the belonging .olb file for Capture?
* Version 271212
User9050
06:20 AM
- Email to a Friend
Regrettably the olb file is not available for the mentioned device.
But you can create it by your own using the "Model Editor" which you can find in the "PSpice Accessories" folder.
Just open the .lib file and use the export function "Export to Capture Part Library".
Check the part's pin numbers to connect gate, source, drain in the right way.
Schulz
Schulz
