Nomenclature
Fränce
5 sign-ins 5 replies posted 10 questions asked
Which nomenclature does Infineon use for SiC devices?
sicguru
First reply posted First solution authored Welcome!
Fränce wrote:
Which nomenclature does Infineon use for CoolSiC MOSFET devices?
For CoolSiC MOSFET Infineon uses a similar nomenclature as for IGBT modules. The main difference is that the RDSon is used instead of the nominal current in the device name following the initial letter combination indicating the module configuration or package type (discrete devices).
Example for modules: FF6MR12W2M1
FF: Half-bridge
6MR: 6 mOhm
12: rated maximum blocking voltage divided by 100
W2: Easy2B
M1: CoolSiC™ MOSFET 1st Generation
Example for discretes: IMW120R045M1
I: Infineon
M: CoolSiC™ MOSFET
W: TO247 3pin package
120: rated maximum blocking voltage divided by 10
R045: 45 mOhm
Hope that helps you - further explanation, you will find on the www.infineon.com
sicguru
FF: Half-bridge
6MR: 6 mOhm
W2: Easy2B
I: Infineon
M: CoolSiC™ MOSFET
R045: 45 mOhm
YUAN
First like received 10 replies posted 5 solutions authored
One other example for discrete:
IMZ120R060M1H
I: Infineon
M: CoolSiC™ MOSFET
Z: TO247 4pin package
R045: 45 mOhm
H: High gate voltage ranges
Fränce
Great. Thanks!
