Ankit_singh
I was using n channel power mosfet
AUIRFP4110.
by applying Vgs=12 V (in series  with 1k resistor) , Parallel resistance between GS was 1K(for fast switching), Vds=50 V .
Mosfet was working fine till 5 Amp load & switching was too good but when I switched the load to 10 Amp ; the mosfet got blown up immediately. Testing scenario was within the specified range as per datasheet ; please let me know your valuable thoughts to rectify this problem.
Ankit Singh
vigneshkumar
25 likes received 250 sign-ins 50 solutions authored
Hi Ankit,
Problem summary as per the discussion we had with you :
MOSFET (AUIRFP4410) blown up while loaded at 10A it was working fine when loaded with 5A. No frequency involved it was one time Turn-ON. Load increased with Rheostat.12VDC Applied to gate through Rg - 1k, Rgs- 1k. Vds- 50V. heat sink details -Unknown. please correct if anything is wrong.
 This could be the Possible cause .
 Rg and Rgs will act as Voltage Divider, Effective voltage at gate would be 6V, lesser the gate voltage higher the Rds-on, which will generate more heat. MOSFET may fail if there is no heatsink used.
   Solution: Rg value should be reduced and add a suitable heatsink. Pls Refer Gate resistor selection.
We can figure out exact issue if you share test setup detail and Vgs, Vds voltage waveform.
Vignesh kumar
vigneshkumar
Hi Ankit,
Thanks for posting in Infineon community.
Could you please share driver detail and frequency of operation?
Vignesh kumar.
I was not using any gate driver ; I had just applied isolated 12V DC as Vgs
through 1k resistor.
Ankit Singh
Electrical Engineer
Phone no. - (+91)9458707512
vigneshkumar
Hi Ankit,
Vignesh kumar
