MOSFET Recommended MPN
KOTO
25 sign-ins First solution authored 5 questions asked
We are looking for MOSFET Recommended MPN
From SPEC, there are 2 choices as below,
IAUT150N10S5N035
 IAUT260N10S5N019
Application is industrila units
So we don't need those automotive grade,
It will be enough and ok with industirla grade
Could you advise us your recommended MPN for infustrial app with as simmilar spec as those MPN.
Takashi_O
10 likes received 250 sign-ins 250 replies posted
Hi, @KOTO
Thank you for posting into our community.
We recommend following devices as OptiMOS5 series and same package option but not automotive grade.
  • IPT026N10N5
  • IPT020N10N5
  • IPT015N10N5
I also made comparison table among the devices, so please find the attached for the details.
Please keep in your mind that you can also use Japanese in this Community.
If this replay solves your issue, please push "Accept as solution" button.
TakashiO
Takashi_O
Hi, @KOTO
  • IPT026N10N5
  • IPT020N10N5
  • IPT015N10N5
TakashiO
